Hey guys. Before I order this, I'm curious if this is worth the money? I have about $150 to spend on a graphics card. Also, any idea what fps I'd get on Bf4 on medium-high settings? Thanks! http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=8687110
This is a good card but, I recommend looking around for GTX 650 Ti Boost because it spanks the R7 260x in price to performance ratio. If you are willing to pay a lil more TigerDirect has one for about $185.
Here the link to the card: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7889694&CatId=7387
Benchmarks of the R7 260x vs GTX 650 Ti Boost : http://www.legitreviews.com/amd-radeon-r7-260x-versus-nvidia-geforce-gtx-650-ti-boost_125834/3
Alright. Thanks for the help!
If he was going to spend that amount of money why not just buy a 270 non-x? which is better then the 650 ti boost for the same-ish price?
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121823
http://www.techpowerup.com/reviews/ASUS/R9_270_Direct_Cu_II_OC/7.html
You have a point. I did not think of that card at the moment but it would be a way better option then what I recommended.
It's a good card, the Boost will beat it but just like what thyskea said, the R9 270 will beat the boost for a same price.
