I was hoping you could help me with crossfire problem Im having. My xfx r9 290s run great on their own, but when ever I try to crossfire them my system freezes up in game. Anyone else run into a problem like this?
I just came from the 970 chipset and can personally verify that its abit lacking. I never ran xfire on it but from what I have read it can be an issue. Also a 1000W PSU would help you out as well and leave you much better headroom.
970 Codenamed RX980 One physical PCIe 2.0 ×16 slot, one PCIe 2.0 ×4 slot and three PCIe 2.0 ×1 slots, the chipset provides a total of 22 PCIe 2.0 lanes and 4 PCIe 2.0 for A-Link Express III solely in the Northbridge HyperTransport 3.0 up to 2400 MHz and PCI Express 2.0 13.6 Watt TDP Southbridge: SB950/SB920
990FX - Latest one. Codenamed RD990 Four physical PCIe 2.0 ×16 slots @ x8 electrical which can be combined to create two PCIe 2.0 ×16 slots @ x16 electrical, one PCIe 2.0 ×4 slot and two PCIe 2.0 ×1 slots, the chipset provides a total of 38 PCIe 2.0 lanes and 4 PCIe 2.0 for A-Link Express III solely in the Northbridge HyperTransport 3.0 up to 2600 MHz and PCI Express 2.0 ATI CrossFireX supporting up to four graphics cards 19.6 Watt TDP Southbridge: SB950 Enthusiast discrete multi-graphics segment
I would agree your PSU is a bit on the weak side, use a GPU tweaking program like MSI Afterburner to underclock/undervolt your cards and see if you have the same issue. If not, it's likely your PSU that is the problem; for my 290x crossfire build I put in a 1300 watt PSU, A little overkill but you get the point. Each card could be drawing as much as 450 watts at full load; while you are unlikely to hit that kind of power drainage; with a 8350, some hard drives, fans, and stuff you could max out a 850 watt without trying very hard.
But keep in mind that on a 970 chipset board, an Xfire only runs at 4x gen2. So it could be the motherboard. The mobo isnt realy great in the first place, but yeah its allways hard to say.
I'm afraid you really have to swap the board. I heard buying in USA you are able to return the product as long as it is intact or there is a try out time right?
Its not the psu for sure, went out yesterday and picked up a 1050watt gold psu.. And it did nothing. Kinda bummed but not really, im planning on doing a custom water loop later down the line. As far as drivers, I installed and uninstalled them twice.
The next logical explanation would be the second card having problems running at 4x in crossfire. A 990fx board like a Asus 990fx pro, Asrock extreme 9, Asus Sabertooth, Asrock Fatality or Asus Crosshair V should if it if it is a pcie problem. It could be drivers or something else but if it is pcie limitations, those motherboards should fix it.
