XFX 7970 for £200? Is this good value? I stumbled across it on Amazon while i was contemplating a new build and it seemed quite good. Currently the only machine i have is a MacBook Air and i'm missing playing games.
Any knowledge or advice would be greatly appreciated.
Is that in terms of heat or noise? I guess both would be bad. What would be a good brand for quiet effective coolers? I hope these cards would be suitable for a Mini ITX build, i mean in terms of size.
Good choices. Just be sure to check any clearance measures. Any good online vendor will specify the length of cards that the chassis can handle. Or heatsink height et cetera.
This is the only forum that I have stayed with. Haven't tried many. Sometimes it would be for a game like DayZ or Total War. I only really feel the need to stick with this one. Get to know quite a few people.
Well i used to use the Custom PC forums (and subscribed to the magazine) until they got shut down and merged with Bit-Tech. Havent really got into Bit-Tech so hopefully this is what im looking for. We shall see.
