I don't have admin rights to my router and resetting it, to login via admin:password isn't an option. (yes I know how etc, and I've done it before)
How can I bypass it's firewall and play games online :/ it pings forever due to the firewall built into the router.
What model of router do you have.
:o
You should be able to hook up your own modem and a separate router, I've got a neighbor on Comcast who does that and it works fine. If you need the phone function, try having Comcast put it in Bridge Mode and use a separate router.
They also may refer to it as IP passthrough.
