Xeon phi bitcoin mining?
Is it possible to use a xeon phi for bitcoin mining and what would the performance look like?
ntel® Xeon Phi™ Coprocessor 3120A
(6GB, 1.100 GHz, 57 core)
Mining with processors is not efficient at all. I can't imagine it would very good even with 57 cores. My 8350 gets around 9Mhs.
It's a co-processor mostly used for weather simulations, iirc.
xeon phi isnt really a CPU its an assisting GPU.
It's not a GPU it's a Co-processor which is actually a glorified x86-x64 CPU with lots and lots of cores.
Also to the OP, considering Intel's track record with their CPU Hash rates being garbage, I would seriously doubt that you could get much out of this thing with the slow speed its running at even with 57 cores.
i've read that it has vector processing units, which would be different than x86-64. or maybe it has both.
EDIT: https://bitcointalk.org/index.php?topic=153587.0
turns out to be as effective as an AMD gpu.
