XENSERVER - Nvidia grid cards not showing up correctly with smi
The case
I’m currently testing the difference between what the Citrix CenCenter shows about my GPU (Grid K2) and what the NVIDIA SMI util is showing.
Data
This is a table of my findings
gpudata
and here is server 6 server6
The Question
Why do the NVIDIA SMI not show me the whole picture?
I would like to just ssh to my server and check the damm cards.
Any ideas why the SMI is not showing my cards?
There’s a kind of involved VMware setup here… do you know what mode your gpus are in for VMware? You may need to disable ecc… Had to do that on the v100.
Any errors from VMware side of it? Maybe it’s having trouble loading a module.
The grid k2 support in modern drivers is a bit sketch. Because licensing. So… Not sure we have enough info here.
  1. Thanks for the reply.
  2. All of this is running on XenServer :wink:
    I have looked at the xen logs, and there is no mention of errors or the gpu cards not reporting correctly.
This is what zen reports back. There are 3 Grid K2 Cards in this system. And as the cli screenhot shows. It’s the same on this server.
But i have an other server where i get this view.
Here the smi only shows 1 gpu…
Som setup information:
XenServer 7.1C1
2x E5-2667
512GB ECC
