Hi There! Hoping someone could help as I am banging my head against a wall! I am trying to get GPU passthrough to work within a Windows VM.
The problem I keep running into is that no matter what I do the VM console that is normally created for config and initial access by XCP-ng is still enabled when GPU passthrough is turned on, and I am left with the console showing up as a second gpu with windows default display drivers, interfering with other programs.
Just wondered if someone else had run into this, or whether there was a way to force disable the VM console.
