Went to turn on my Xbox.....and it turns on and I get the power green power logo, but no boot or outer rings, TV doesn't receive a signal and the wireless adapter at the back has no power light on it (this only flashes on for a second if I plug or unplug it from the USB port on the xbox.....though it come on if I plug it into my PCs USB port)???
So much for my planed night of Bioshock Infinite
(I have tried using another hdmi cable, unplugging everything and reconnecting all the cable then powering TV and Xbox up again)
System Info = (RGH) Xbox 360 Elite - HTMI- Philips BENQ -Xecutor Cool Runner - FSD 2.2 - Talismoon Whisper Fan - 2.0.14719.0 - DashLaunch v2.32 - LT+ 3.0. .
Checked all the USB ports, and same problem in all of them...redlight just flashes for a second on the wifi adaptor (though even without the light being on I can turn the xbox on with the middle X button on a wireless controller, but it wont synic with the xbox, and the xbox still wont boot.
Cracked it open to see if it was something obvious like a blown electrolytic cap or a lose solder, but no joy!
Even continuity checked all the Cool Runner connections with my multimeter.
Im also getting power from all all the USB ports, and have cracked open the wireless adaptor to see is the mini USB cable that plugs into the PCB had come loose. :(
