Was hoping I might get specific answers here. I am looking for an X99 MOBO (preferable mostly black or black and white) that has (2) Intel NIC hookups, will work with VT-D znd Linux, and has great support for an M.2 SSD without bogging down the lanes for the GPU's?
I will be running an i7 5930K and will need to have (2) GPU's running, not in crossfire, for the Linux/Windows setup I am wanting/needing to get going.
Yes it works with hardware passthrough, at least in kvm and Xen. I have three systems running them on SuSE with no problems at all. Two of these systems use hardware passthrough on a PCIe slot (not a GPU, but it should be the same for GPU's).
@Zoltan, I am confused because in older posts relating to this matter you have stated to avoid the Asus MOBO's? Did something change with the 2011-3 boards?
Be a little wary of the X99 Asus boards of you plan to use Vt-D. On the AMD side Asus is known to mess with some things required for it to work properly. Not sure if they do with Intel boards as well just a thought to put out there. Personally them messing with the extensions on purpose (even if only on AMD boards) is enough reason for me to never buy their boards
If color theme was not an issue, then i would go with the Asrock X99 WS. Its currently on sale at newegg for arround $254,- after MiR, @Logan uses this particular board in his rig. It does feuture dual intel nic´s, and ultra m.2
I dont think you can find and other board that is workstation class in this price category. Its realy good value for money i guess.
