I’m currently building a PC. I don’t have all the parts yet and I’m hoping that’s the issue but, I just installed the CPU (R9 7900X) and the cooler (Arctic Liquid Freezer 3). The first time I put the CPU in the black socket cover didn’t pop, so I took it out, visually examined both the CPU and the socket, but I didn’t see anything.
Then I put it back and it correctly popped. The cooler also took quite a bit of force to install (see the Gamers Nexus video at 23:00 as I had that same issue). But I managed after a few attempts.
When I finally turned the machine on I just got the Post Status Checker light for the CPU.
Of note is that I have no RAM yet, but also that PSC light wasn’t even on.
What are my options/possibilities here?
Do I need RAM?
Could I have broken the CPU? Or the motherboard (it’s LEDs still work and fans spin up, although the Artic cooler fans do not spin up, but the pump does activate).
After today I won’t even be able to work on the machine until the 16th. I won’t be physically near it for RMA either (if that were even an option to begin with).
I’m really scared that I’ve majorly screwed up.
Update:
I probably did freak out for nothing (though not without cause). I was able to secure some DDR5 RAM borrowed from a friend and have been running the system for the past couple hours, even running benchmarks, without issue.
Moral of the story is I guess make sure you have both a CPU and RAM (even though I thought the BIOS said you didn’t need RAM) before you try doing anything since you’ll probably jump to a bad conclusion.
So you’re trying to POST with no memory and want to know if it is normal the CPU light is on?
I have no idea, but I honestly wouldn’t worry too much about it. The POST led on my board (Asus) is not that reliable, since it only has a few colors to encode a bunch of different codes. I’ve had it on red (CPU) when I had pushed my memory too much, for example.
I also remember needing a lot of force to get the black socket cover to pop, I don’t think it means you broke anything.
I don’t think it would be easy to verify what this board does with a CPU correctly installed but no memory. You’d need to find someone with the same motherboard who is willing to test for you… Also if you broke something you shouldn’t RMA, and if you have a faulty product you’ll be able to RMA or at least use warranty after the 16th?
I don’t know if this is a cultural thing (EU vs US?) but people RMA’ing stuff they broke/operated wrong/just want to replay silicon lottery rub me the wrong way. You’ll have the store/its other customers pay for your own errors and entitlement…
While I wouldn’t intend to cause someone financial lost, it’s certainly built into the operating costs if a company is going to even offer such a thing.
But hey, thankfully it seems everything is alright.
On the topic of self check LEDs, my board has 4, labeled CPU, RAM, VGA and BOOT, And while they could have more variation/specificty, I think that’s actually decent detail, at least with the first 2.
Also did you connect both the 24 pin motherboard power,
and 8 pin / and or (4+4) pin cpu power connectors?
Because if you did not at least connect one of the 8 pin cpu power connectors,
the system won´t post and also shows a cpu error led light up.
The motherboard basically has two 8 pin cpu power connectors,
from which at least one should be connected.
But i basically advice to just connect both of them.
