So i got a Nehalem CPU i wanted to keep running for sentimental value, but i also didn’t want to have another big black coffin sitting around, so i looked around for a small LGA 1366 motherboard. There weren’t any mini-ITX ones, but i did find a microATX one - Machinist branded, X58 chipset. Good enough.
The board worked just fine, the CPU is still alive and well and performs as expected.
It draws 20-40W depending on the load, and peaks out around 60W.
With a GT 710 plugged in, that is.
What i wanted is a small headless box, so once everything was checked and configured, i removed the GPU and tried again.
Nope. It would draw 70-90W continuously for about the same 20 seconds as it would normally take it to boot, then drops down to 30W for a second, then power cycles. Again and again. No signs of it getting into Linux either.
I’ve looked around the BIOS, tried things like “Headless mode” under ACPI settings, to no effect.
It’s not the end of the world, i can spare an old GPU for the project, but it’s not as nice.
So, do anyone have any clues as to why an X58 motherboard would draw way more power than normal and refuse to work without a GPU? Am i missing something obvious?
