I have an Evga X58 i7 What to buy Next in build part by part?
Only have x58 motherboord
bring from old system: Death Adder mouse
Destructor mouse pad
reclusa key bourd
an i7 920, only $300, highly worth it. I don't see a point in the 940, it's twice the price, and the 965 if you are a millionaire.
I was thinking 940 how fare can you push a 940.
dont want to go to fare.
uhh the 940 on air could go around 3.8-4Ghz just like the 920.
zzlee14 wrote 6 minutes ago »
Yeah, 920 and 940 are same chip, except the 940 passed more/harder factory tests before being set for packaging, so overclocking is more or less the same.
just get a 920, 940 is a waste. with that extra money u could get alot of other stuff
You can get your boy friend some good items.
Thanks Scump
I did no know they were the same thing.
zzlee14 wrote 1 minute ago »
Thanks Scump
rofl, scump....
its skump
sorry skump I send him :)
yeah, it's either 920 or 965, depending on your budget. If you don't pirate dvds, then you'll probably only be able to afford the 920.
you can get the 920 to 4.0 on air thats the average of what everyones going for
get the 920 and underclock it to 1.66 GHZ
920 is a superb cpu for the price you cannot beat it all suggest 6 gb of ram
that means I need to get 64 bit xp,vista or windows 7
