Hi,
Does anyone else have any issues with the RESET SWITCH? I was in the BIOS just testing a few things and pressed the RESET SWITCH but it didn’t reset at all, it stayed on the BIOS page. I did check the connection of my case’s RESET button pinout was correct, green on the positive and black on the GND.
Is it possible this can be disabled in the BIOS? I checked but didn’t find anything.
Anyone else had the same issue or noticed the same thing? There is a mention in the manual to press the reset switch in case of boot failure so I wonder if it will only work when there is a failure and if that is a safeguard against resets which you wouldn’t want by accident in a server environment?
