I am getting a voltage mismatch error on my vcl after installing the x5460's...It boots into BIOS but because of the error I can not boot past BIOS...In theory these are supported and I don't see anything saying that they are not...I updated the BIOS to 86 and still no go....Any ideas? I don't get why it boots up and lets me in BIOS if they are not supported
Update the bios. The latest version is 101.something
Alright I'll try that version....Updating BIOS on this thing is so hard to do lol
You can use rufus to create a dos-bootable usb, boot to that, and use intel's dos updating bios package to install it that way. But if you know of a way to do it otherwise, then I'd just do what you know.
I only see the windows flash version, can you link me to the dos flash one
I wonder if IDA(Intel deployment assistant) works off of a flash drive lol
hmm, well I'm not sure but I would read through this forum thread if I were you: https://communities.intel.com/thread/8697
its a no go, i ended up buying new motherboard that they do boot in and built a different system, real shame and alot of $$$
