Switched the boot slot from 1 to 4.
Here’s the lspci:
https://pastebin.com/VcWWA3cx
No change, still only able to pass-through the card in slot 4. Also able to pass through a pcie wifi card and a nvme drive (they are attached to vfio-pci successfully)
showing my kernel boot link, and the vfio-pci error -22
dmesg |grep vfio
[ 0.000000] Command line: BOOT_IMAGE=/bzimage vfio-pci.ids=10de:1b80,10de:10f0,1002:6707,1002:aa80,15b7:5002,8086:24fd pcie_acs_override=downstream,multifunction initrd=/bzroot,/bzroot-gui
[ 0.000000] Kernel command line: BOOT_IMAGE=/bzimage vfio-pci.ids=10de:1b80,10de:10f0,1002:6707,1002:aa80,15b7:5002,8086:24fd pcie_acs_override=downstream,multifunction initrd=/bzroot,/bzroot-gui
[ 12.175871] vfio-pci 0000:0a:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 12.188064] vfio_pci: add [10de:1b80[ffff:ffff]] class 0x000000/00000000
[ 12.200289] vfio_pci: add [10de:10f0[ffff:ffff]] class 0x000000/00000000
[ 12.208250] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 12.216157] vfio_pci: add [1002:6707[ffff:ffff]] class 0x000000/00000000
[ 12.224024] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 12.232057] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 12.239960] vfio_pci: add [1002:aa80[ffff:ffff]] class 0x000000/00000000
[ 12.259269] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 12.267215] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 12.275010] vfio_pci: add [15b7:5002[ffff:ffff]] class 0x000000/00000000
[ 12.295284] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 12.303230] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 12.311048] vfio_pci: add [8086:24fd[ffff:ffff]] class 0x000000/00000000
41:00 is the FirePro, failed to bind to vfio-pci
15b7:5002 is an nvme
8086:24fd is a wifi card
10de:1b80 10f0 is the GTX 1080 and its sound interface
same command from another boot where I tried to force the gt310 to vfio
root@Tower:~# dmesg |grep vfio
[ 0.000000] Command line: BOOT_IMAGE=/bzimage vfio-pci.ids=10de:0a63,10de:0be3,10de:1b80,10de:10f0,1002:6707,1002:aa80,15b7:5002,8086:24fd pcie_acs_override=downstream,multifunction initrd=/bzroot
[ 0.000000] Kernel command line: BOOT_IMAGE=/bzimage vfio-pci.ids=10de:0a63,10de:0be3,10de:1b80,10de:10f0,1002:6707,1002:aa80,15b7:5002,8086:24fd pcie_acs_override=downstream,multifunction initrd=/bzroot
[ 7.640943] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.641226] vfio_pci: add [10de:0a63[ffff:ffff]] class 0x000000/00000000
[ 7.641505] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.641834] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.642113] vfio_pci: add [10de:0be3[ffff:ffff]] class 0x000000/00000000
[ 7.642416] vfio-pci 0000:0a:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[ 7.654216] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.654463] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.654640] vfio_pci: add [10de:1b80[ffff:ffff]] class 0x000000/00000000
[ 7.666150] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.674072] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.681859] vfio_pci: add [10de:10f0[ffff:ffff]] class 0x000000/00000000
[ 7.689664] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 7.697457] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.705294] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.713088] vfio_pci: add [1002:6707[ffff:ffff]] class 0x000000/00000000
[ 7.720922] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 7.728830] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 7.736658] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.744503] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.752284] vfio_pci: add [1002:aa80[ffff:ffff]] class 0x000000/00000000
[ 7.772114] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 7.780100] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 7.787892] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.795775] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.803572] vfio_pci: add [15b7:5002[ffff:ffff]] class 0x000000/00000000
[ 7.823195] vfio-pci: probe of 0000:41:00.0 failed with error -22
[ 7.831145] vfio-pci: probe of 0000:41:00.1 failed with error -22
[ 7.838947] vfio-pci: probe of 0000:42:00.0 failed with error -22
[ 7.846866] vfio-pci: probe of 0000:42:00.1 failed with error -22
[ 7.854697] vfio_pci: add [8086:24fd[ffff:ffff]] class 0x000000/00000000
long story short, devices in slot 1 and 2 are unable to bind to vfio, with error -22
