hey all, something that i came across, is that, although many cases the type-d on the front I/O, not all x399, even higher end ones have a usb 3.1 type-c header. i havent found a way to search for motherboards that have that header, so what boards have you all seen the do have that header?
https://www.gigabyte.com/Motherboard/X399-DESIGNARE-EX-rev-10#kf
The Designare has both a front and read USB 3.1 Type C connector.
This also has a 3.1 front connector.
i might go with that asus board, for as expensive as it is, it didnt add that much to the total cost, and it seems to have good linux support. EDIT, never mind, it only has 1 m.2 slot, and im looking to use 2 of them, si i guest im going with the gigabyte board, and plus, its RGBless
