I have an old fat Xbox 360 that I'd like to devote to various modding projects, one of which is using aftermarket coolers for the CPU and GPU to replace the horrendously terrible stock fanless heatsinks (preferably with some low profile coolers). I'm thinking of powering them using the same header used for the dual fan at the back of the console, soldered to an expansions board of some description, so my first question would be this - does the fan header have enough power to power 2 CPU/GPU coolers (and maybe and additional case fans) or would I need a more inventive solution?
A cursory inspection of the motherboard looks as though the current X-clamp design for the heatsinks could accommodate an intel push-pin style cooler without much hassle, so my second question is whether any kinds of PC heatsinks can be fitted to the motherboard without, say, drilling any additional holes.
Thanks.
