As you can see the supplied 2.54MM serial cable does not fit this motherboard as it requires a 2.0MM cable. I have contacted ASUS but they offer no help and sent me another incorrect cable.
Just a heads up if you buy this motherboard.
Can you check how that port is labeld? The manual does not tell.
That port has no identification on it and it has a 2.0mm pitch so the included com port bracket wont fit or reach that far.
Found a bag of 2x5 connectors in my collection that could fit. Problem is: I can´t test if they do and some asshat (me) pulled the label off (if there ever was one).
Will edit this post if I find out the name and where you can get the part (will probably be 20 cents or so). Pretty sure that is molex Mini-Latch series… Piece of shit connectors that break all the time in everything…)
I suspect that is some type of recovery header. It’s not present under device manager if its an additional serial port.
