I have a 24" Samsung SyncMaster P2450 (1920x1080) and a secondary monitor 17" Dell (1024x768). The secondary should be positioned at the right and aligned to the bottom. But the configuration is not remembered after a restart: the secondary shows the same as the SyncMaster (cropped at 1024x768). I always have to reposition the screens on the nvidia x server settings in the display configuration. saving the changes to xorg.conf (made by the configuration window) does not help.
What changes have to be made to remember the display positions?
Here’s the (current) config saved by the settings dialog:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 367.35 (buildd@lgw01-18) Tue Aug 9 10:11:49 UTC 2016
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "Module"
Load "dbe"
Load "extmod"
Load "type1"
Load "freetype"
Load "glx"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: builtin, VertRefresh source: builtin
Identifier "Monitor0"
VendorName "Unknown"
ModelName "CRT-0"
HorizSync 28.0 - 55.0
VertRefresh 43.0 - 72.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "GeForce GTX 960"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-4"
Option "metamodes" "DVI-I-0: nvidia-auto-select +1920+312, DVI-D-0: nvidia-auto-select +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
