X11 and Evdev not getting along. USB input
I have a Logitech G600 USB mouse. i’ve got all the top buttons and mouse tilt working fine, but the thumb keys are a problem. evtest can see the correctly rebound thumb key inputs, but X11 cannot. confirmed by xev. turns out Piper is useless on this mouse. scancodes need to be mapped to keycodes. Debian Bookworm.
here is my /etc/udev/hwdb.d/69-custom.hwdb
69-custom.hwdb
evdev:input:b*v046DpC24A*
#top button
 KEYBOARD_KEY_70010=btn_8
#mwheel tilting
 KEYBOARD_KEY_7000f=btn_right
 KEYBOARD_KEY_70015=btn_left
#thumb keys
 KEYBOARD_KEY_70059=key_macro1
 KEYBOARD_KEY_7005a=key_macro2
 KEYBOARD_KEY_7005b=key_macro3
 KEYBOARD_KEY_7005c=key_macro4
 KEYBOARD_KEY_7005d=key_macro5
 KEYBOARD_KEY_7005e=key_macro6
 KEYBOARD_KEY_7005f=key_macro7
 KEYBOARD_KEY_70060=key_macro8
 KEYBOARD_KEY_70061=key_macro9
 KEYBOARD_KEY_70062=key_macro10
 KEYBOARD_KEY_70005=key_macro11
 KEYBOARD_KEY_70004=key_macro12
and here is my /etc/X11/xorg.conf.d/50-logitech.conf
50-logitech.conf
Section "InputClass"
    Option "Device" "/dev/input/by-id/usb-Logitech_Gaming_Mouse_G600_47FC513CA1FB0017-if01-event-mouse"
    Identifier "G600 misconfiguration fix"
    MatchProduct "G600"
    Driver	"evdev"
    # Match just the keyboard section of the G600
    MatchIsKeyboard "true"
    # evdev assumes it is a mouse when it sees the absolute axis. Stop that from happening.
    Option "IgnoreAbsoluteAxes" "on"
EndSection
here’s the output of evtest when i press each button in order.
evtest
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0x46d product 0xc24a version 0x111
Input device name: "Logitech Gaming Mouse G600 Keyboard"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 1 (KEY_ESC)
    Event code 2 (KEY_1)
    Event code 3 (KEY_2)
    Event code 4 (KEY_3)
    Event code 5 (KEY_4)
    Event code 6 (KEY_5)
    Event code 7 (KEY_6)
    Event code 8 (KEY_7)
    Event code 9 (KEY_8)
    Event code 10 (KEY_9)
    Event code 11 (KEY_0)
    Event code 12 (KEY_MINUS)
    Event code 13 (KEY_EQUAL)
    Event code 14 (KEY_BACKSPACE)
    Event code 15 (KEY_TAB)
    Event code 16 (KEY_Q)
    Event code 17 (KEY_W)
    Event code 18 (KEY_E)
    Event code 19 (KEY_R)
    Event code 20 (KEY_T)
    Event code 21 (KEY_Y)
    Event code 22 (KEY_U)
    Event code 23 (KEY_I)
    Event code 24 (KEY_O)
    Event code 25 (KEY_P)
    Event code 26 (KEY_LEFTBRACE)
    Event code 27 (KEY_RIGHTBRACE)
    Event code 28 (KEY_ENTER)
    Event code 29 (KEY_LEFTCTRL)
    Event code 30 (KEY_A)
    Event code 31 (KEY_S)
    Event code 32 (KEY_D)
    Event code 33 (KEY_F)
    Event code 34 (KEY_G)
    Event code 35 (KEY_H)
    Event code 36 (KEY_J)
    Event code 37 (KEY_K)
    Event code 38 (KEY_L)
    Event code 39 (KEY_SEMICOLON)
    Event code 40 (KEY_APOSTROPHE)
    Event code 41 (KEY_GRAVE)
    Event code 42 (KEY_LEFTSHIFT)
    Event code 43 (KEY_BACKSLASH)
    Event code 44 (KEY_Z)
    Event code 45 (KEY_X)
    Event code 46 (KEY_C)
    Event code 47 (KEY_V)
    Event code 48 (KEY_B)
    Event code 49 (KEY_N)
    Event code 50 (KEY_M)
    Event code 51 (KEY_COMMA)
    Event code 52 (KEY_DOT)
    Event code 53 (KEY_SLASH)
    Event code 54 (KEY_RIGHTSHIFT)
    Event code 55 (KEY_KPASTERISK)
    Event code 56 (KEY_LEFTALT)
    Event code 57 (KEY_SPACE)
    Event code 58 (KEY_CAPSLOCK)
    Event code 59 (KEY_F1)
    Event code 60 (KEY_F2)
    Event code 61 (KEY_F3)
    Event code 62 (KEY_F4)
    Event code 63 (KEY_F5)
    Event code 64 (KEY_F6)
    Event code 65 (KEY_F7)
    Event code 66 (KEY_F8)
    Event code 67 (KEY_F9)
    Event code 68 (KEY_F10)
    Event code 69 (KEY_NUMLOCK)
    Event code 70 (KEY_SCROLLLOCK)
    Event code 71 (KEY_KP7)
    Event code 72 (KEY_KP8)
    Event code 73 (KEY_KP9)
    Event code 74 (KEY_KPMINUS)
    Event code 75 (KEY_KP4)
    Event code 76 (KEY_KP5)
    Event code 77 (KEY_KP6)
    Event code 78 (KEY_KPPLUS)
    Event code 79 (KEY_KP1)
    Event code 80 (KEY_KP2)
    Event code 81 (KEY_KP3)
    Event code 82 (KEY_KP0)
    Event code 83 (KEY_KPDOT)
    Event code 85 (KEY_ZENKAKUHANKAKU)
    Event code 86 (KEY_102ND)
    Event code 87 (KEY_F11)
    Event code 88 (KEY_F12)
    Event code 89 (KEY_RO)
    Event code 90 (KEY_KATAKANA)
    Event code 91 (KEY_HIRAGANA)
    Event code 92 (KEY_HENKAN)
    Event code 93 (KEY_KATAKANAHIRAGANA)
    Event code 94 (KEY_MUHENKAN)
    Event code 95 (KEY_KPJPCOMMA)
    Event code 96 (KEY_KPENTER)
    Event code 97 (KEY_RIGHTCTRL)
    Event code 98 (KEY_KPSLASH)
    Event code 99 (KEY_SYSRQ)
    Event code 100 (KEY_RIGHTALT)
    Event code 102 (KEY_HOME)
    Event code 103 (KEY_UP)
    Event code 104 (KEY_PAGEUP)
    Event code 105 (KEY_LEFT)
    Event code 106 (KEY_RIGHT)
    Event code 107 (KEY_END)
    Event code 108 (KEY_DOWN)
    Event code 109 (KEY_PAGEDOWN)
    Event code 110 (KEY_INSERT)
    Event code 111 (KEY_DELETE)
    Event code 113 (KEY_MUTE)
    Event code 114 (KEY_VOLUMEDOWN)
    Event code 115 (KEY_VOLUMEUP)
    Event code 116 (KEY_POWER)
    Event code 117 (KEY_KPEQUAL)
    Event code 119 (KEY_PAUSE)
    Event code 121 (KEY_KPCOMMA)
    Event code 122 (KEY_HANGUEL)
    Event code 123 (KEY_HANJA)
    Event code 124 (KEY_YEN)
    Event code 125 (KEY_LEFTMETA)
    Event code 126 (KEY_RIGHTMETA)
    Event code 127 (KEY_COMPOSE)
    Event code 128 (KEY_STOP)
    Event code 129 (KEY_AGAIN)
    Event code 130 (KEY_PROPS)
    Event code 131 (KEY_UNDO)
    Event code 132 (KEY_FRONT)
    Event code 133 (KEY_COPY)
    Event code 134 (KEY_OPEN)
    Event code 135 (KEY_PASTE)
    Event code 136 (KEY_FIND)
    Event code 137 (KEY_CUT)
    Event code 138 (KEY_HELP)
    Event code 183 (KEY_F13)
    Event code 184 (KEY_F14)
    Event code 185 (KEY_F15)
    Event code 186 (KEY_F16)
    Event code 187 (KEY_F17)
    Event code 188 (KEY_F18)
    Event code 189 (KEY_F19)
    Event code 190 (KEY_F20)
    Event code 191 (KEY_F21)
    Event code 192 (KEY_F22)
    Event code 193 (KEY_F23)
    Event code 194 (KEY_F24)
    Event code 240 (KEY_UNKNOWN)
    Event code 264 (BTN_8)
    Event code 272 (BTN_LEFT)
    Event code 273 (BTN_RIGHT)
    Event code 656 (?)
    Event code 657 (?)
    Event code 658 (?)
    Event code 659 (?)
    Event code 660 (?)
    Event code 661 (?)
    Event code 662 (?)
    Event code 663 (?)
    Event code 664 (?)
    Event code 665 (?)
    Event code 666 (?)
    Event code 667 (?)
  Event type 4 (EV_MSC)
    Event code 4 (MSC_SCAN)
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    250
    Repeat code 1 (REP_PERIOD)
      Value     33
Properties:
Testing ... (interrupt to exit)
Event: time 1680380647.699620, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70010
Event: time 1680380647.699620, type 1 (EV_KEY), code 264 (BTN_8), value 1
Event: time 1680380647.699620, -------------- SYN_REPORT ------------
Event: time 1680380647.816402, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70010
Event: time 1680380647.816402, type 1 (EV_KEY), code 264 (BTN_8), value 0
Event: time 1680380647.816402, -------------- SYN_REPORT ------------
Event: time 1680380648.199382, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70059
Event: time 1680380648.199382, type 1 (EV_KEY), code 656 (?), value 1
Event: time 1680380648.199382, -------------- SYN_REPORT ------------
Event: time 1680380648.352397, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70059
Event: time 1680380648.352397, type 1 (EV_KEY), code 656 (?), value 0
Event: time 1680380648.352397, -------------- SYN_REPORT ------------
Event: time 1680380648.641388, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005a
Event: time 1680380648.641388, type 1 (EV_KEY), code 657 (?), value 1
Event: time 1680380648.641388, -------------- SYN_REPORT ------------
Event: time 1680380648.808400, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005a
Event: time 1680380648.808400, type 1 (EV_KEY), code 657 (?), value 0
Event: time 1680380648.808400, -------------- SYN_REPORT ------------
Event: time 1680380649.227439, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005b
Event: time 1680380649.227439, type 1 (EV_KEY), code 658 (?), value 1
Event: time 1680380649.227439, -------------- SYN_REPORT ------------
Event: time 1680380649.349621, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005b
Event: time 1680380649.349621, type 1 (EV_KEY), code 658 (?), value 0
Event: time 1680380649.349621, -------------- SYN_REPORT ------------
Event: time 1680380649.730406, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005c
Event: time 1680380649.730406, type 1 (EV_KEY), code 659 (?), value 1
Event: time 1680380649.730406, -------------- SYN_REPORT ------------
Event: time 1680380649.888401, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005c
Event: time 1680380649.888401, type 1 (EV_KEY), code 659 (?), value 0
Event: time 1680380649.888401, -------------- SYN_REPORT ------------
Event: time 1680380650.136722, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005d
Event: time 1680380650.136722, type 1 (EV_KEY), code 660 (?), value 1
Event: time 1680380650.136722, -------------- SYN_REPORT ------------
Event: time 1680380650.280405, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005d
Event: time 1680380650.280405, type 1 (EV_KEY), code 660 (?), value 0
Event: time 1680380650.280405, -------------- SYN_REPORT ------------
Event: time 1680380650.507406, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005e
Event: time 1680380650.507406, type 1 (EV_KEY), code 661 (?), value 1
Event: time 1680380650.507406, -------------- SYN_REPORT ------------
Event: time 1680380650.635405, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005e
Event: time 1680380650.635405, type 1 (EV_KEY), code 661 (?), value 0
Event: time 1680380650.635405, -------------- SYN_REPORT ------------
Event: time 1680380651.184409, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005f
Event: time 1680380651.184409, type 1 (EV_KEY), code 662 (?), value 1
Event: time 1680380651.184409, -------------- SYN_REPORT ------------
Event: time 1680380651.324389, type 4 (EV_MSC), code 4 (MSC_SCAN), value 7005f
Event: time 1680380651.324389, type 1 (EV_KEY), code 662 (?), value 0
Event: time 1680380651.324389, -------------- SYN_REPORT ------------
Event: time 1680380651.514707, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70060
Event: time 1680380651.514707, type 1 (EV_KEY), code 663 (?), value 1
Event: time 1680380651.514707, -------------- SYN_REPORT ------------
Event: time 1680380651.658406, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70060
Event: time 1680380651.658406, type 1 (EV_KEY), code 663 (?), value 0
Event: time 1680380651.658406, -------------- SYN_REPORT ------------
Event: time 1680380651.867433, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70061
Event: time 1680380651.867433, type 1 (EV_KEY), code 664 (?), value 1
Event: time 1680380651.867433, -------------- SYN_REPORT ------------
Event: time 1680380651.984421, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70061
Event: time 1680380651.984421, type 1 (EV_KEY), code 664 (?), value 0
Event: time 1680380651.984421, -------------- SYN_REPORT ------------
Event: time 1680380652.445588, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70062
Event: time 1680380652.445588, type 1 (EV_KEY), code 665 (?), value 1
Event: time 1680380652.445588, -------------- SYN_REPORT ------------
Event: time 1680380652.597420, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70062
Event: time 1680380652.597420, type 1 (EV_KEY), code 665 (?), value 0
Event: time 1680380652.597420, -------------- SYN_REPORT ------------
Event: time 1680380652.932396, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70004
Event: time 1680380652.932396, type 1 (EV_KEY), code 667 (?), value 1
Event: time 1680380652.932396, -------------- SYN_REPORT ------------
Event: time 1680380653.073394, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70004
Event: time 1680380653.073394, type 1 (EV_KEY), code 667 (?), value 0
Event: time 1680380653.073394, -------------- SYN_REPORT ------------
Event: time 1680380653.330407, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70005
Event: time 1680380653.330407, type 1 (EV_KEY), code 666 (?), value 1
Event: time 1680380653.330407, -------------- SYN_REPORT ------------
Event: time 1680380653.463395, type 4 (EV_MSC), code 4 (MSC_SCAN), value 70005
Event: time 1680380653.463395, type 1 (EV_KEY), code 666 (?), value 0
Event: time 1680380653.463395, -------------- SYN_REPORT ------------
ive tried xev, but it produces no output when pressing any of the thumb buttons. what am i doing wrong here? what could cause evtest to see a key-press but not X11?
