Hi I'm new here so I don't know where to post.
I installed Wubi on my esternal hardrive a few days ago so I uninstalled it, now when I try to open that hard drive in windows it will load then stops responding then I scream F*** MY LIFE!!!!!!
first off why? also wubi never works right...
also run this and see what you can recove, you should have within four writes before the data is completely gone
https://www.piriform.com/recuva
1st do you want to recover anything from that drive.
if "NO" format it from Disk Management
instructions plug the ext hard drive(do not try to open if something pops up close it) in start menu right click on my computer -> manage ->Disk Management(it is in the right side of the window) it will show every disks connected to your computer find your ext drive and format it.
You should of used pendrivelinux its way better than wubi
I stopped trying to use wubi after 5 minutes because it sucks, but I think has to format the drive before it installs the software
I use Xboot
