Just got a 1080 TI cause YOLO, these gotta go Will be cleaned with distilled water the weekend of 3/18 and will be ready to ship the following Monday. Giving the forum first dibs $400 for the pair or $225 each. US only
Edit: Fuck it, i'll sell this too. Works perfectly, cooler is missing. random CPU cooler is zip tied to it. it's approx a 4-5 slot card now but it works. Temp gun showed the VRM at 67 C after 6 hours of burn in. GPU showed 63c.
$275, will be un-zip tying the cooler from the gpu for shipping because it makes no contact with the die guard. can include zip ties if desired, or i'll just keep the cooler and you can buy just the card.
Used the same settings on both... The card in slot one can go a fair bit higher (1380-1390 range I think) but i kept them clocked the same. 1370 is the highest they will go as a pair. bios modding would probably yield better results.
