My macbook will not turn on and it won't charge. It was on and then it just blacked out and nevder came back on again and I narowed it down to two parts. The magsafe port and the mother board. Witch is it!!!!
It's hard to say without more information. Can you try another charger on the laptop? If it's not charging, chances are the battery is completely flat and therefore won't turn on.
Mine did the same thing it but it won't turn on without being plugged in and holds no charge.
hard to say, apple tends to brick old laptops like that through updates just to force people to upgrade
the laptop's battery has the led'ss on the back light up. put the charger light does not light up.
Why the fuck do you think this?
I don't get it why some people hate macs so much they say shit like this.
And if you are trying to be sarcastic you are not doing a very good job at it you are just making people think you are very ignorant.
Really?! Could you post your evidence? I mean even if you hate the company, which is your opinion and I repespect your right to have it, posting blatant BS is ignorant to the nth degree.
My 13" 2007 macbook wouldnt charge or turn on, so I ended up getting a replament Macbook Magsafe DC jack (part number 820-2627-A) and that did the trick.
But a bit worried that your battery still has power and wont boot......Will it not turn on at all, or just not boot? have you done a NVRAM/PRAM reset?
