WSUS ALternatives?
I really despise WSUS. It’s cumbersome, unstable, unreliable, continues to do whatever it wants regardless of settings and other issues.
Has anyone used WSUS alternatives and which ones are good? I see alot of options, what’s good?
How big is your patching footprint? There are options from anything like PDQ deploy, to Kace.
I actually like WSUS, but haven’t touched it since server 2016. I’d say if you are bent on finding an alternative, figure out how many clients you are patching and find something that fits your need.
We have around 125 workstations + 30-something servers. It’s not a large footprint, all we deploy are MS updates and patches with it. I have looked at a few of the alternatives, but according to their data sheets, they all seem to work in conjunction with WSUS/SCCM as a management piece not a replacement.
Yup, all 3rd party alternatives are just front-ends to WSUS. I also despise Microsoft products but WSUS is the only way to prevent workstations from upgrading Windows 10 builds without approval. In my experience it has been very inefficient with disk space but never unstable or unreliable. If your workstations are doing whatever they want it’s likely group policy settings to blame.
Workstations are working fine. WSUS itself is being contrary. It downloads and attempts to install drivers that I didn’t authorize, it pulls update packs that aren’t listed, etc. If I deny that random driver it decides to download, then run the server cleanup, the database freezes. Then I have to run an external powershell script to clean the DB and restart it.
It’s such a pain to work with.
It shouldn’t be installing drivers without approval unless they’re set as auto approved. Check your settings under Options → Automatic Approvals and make sure both drivers and driver packs are unselected.
And yes, I also agree the cleanup is a PIA. I put a powershell wsus cleanup shortcut on the desktop of the server and a calendar reminder to run it every 90 days (I wasn’t brave enough to create a scheduled task). But can’t say I’ve experienced any freeze ups with the server. If you’re pulling your hair out with it’s performance I’d suggest spinning up a new server and restoring your WSUS data to it. Wish I had something better the suggest.
Nothing is set to auto-approved except for critical updates. It’s not that it’s installing the drivers, but it is downloading them, even tho drivers and driver packs are unchecked, and attaching them to workstation objects, which then won’t install because they haven’t been approved. I have to look at it everyday to see what it decided to download for no reason.
Yup. If Windows 10 1903 and later servicing drivers is selected in your categories it is going to download them regardless of approval status if the workstation has matching hardware. For just current supported versions of Windows 10, Server 2012, 2016, and 2019 I’m using well over a TB of disk space. My suggestion is to give up on trying to keep it skinny and either resize your VHD or migrate to a new VM. It’s going to be bloated no matter what you do :roll_eyes:
Yep, slightly necro’ing a thread.
If I need just Windows 10 updates, what should I select in the Products category for WSUS? We currently are running whatever the latest H version is. Will just the “Windows 10” be enough or do I need to select any of the other options?
