WRX80 Sage problem passing 12 gpu limit
Like the titles says I have a sage and seem to be limited to 12 gpus. Has anyone came up with the proper bios settings to get all 7 slots working in 8x8x mode? As soon as I plug in #13 no post.
I have tried toggling off all the unneeded features on the MB but something is still wrong. I have heard of 14gpus but no one seems to know how.
Any help would be greatly appreciated.
Oh and the bifurcation risers I am using are the maxcloudon ones. I have tried plugging in straight to the MB with the last slot and it doesnt work either so I dont think its a riser issue.
csm disabled, above 4g enabled, Re-Bar enabled?
Yes, Yes, Yes. Tried rebar on and off. I was told the problem is probably mixing a5000s and 3090s in the same system. I understand why windows would treat those cards differently but I am not even getting a post so I dont think that is my problem. That being said, the only systems I have seen over 12 gpus are a series only.
have you tried more basic gpus
even with rebar and above 4G having like 14x24GB VRAM would be a tough order
No, I have only tried 24gb vram gpus I simply dont have a set of other gpus.
That’s a interesting thought that I haven’t looked into. Can you explain to me why this would potentially be a issue?
