I need to activate my product key to keep all the options for windows 7
I bought a legit copy of windows 7, but apparently I bought the upgrade version when I did a clean install. So my product key wont work.
I know a lot of people are against pirating, but im not gonna buy another copy of windows 7 just to get some product key. Can anyone help?
That doesnt make sense. The product key should still work even if it is an upgrade... or atleast thats the only thing that makes sense to me. Might just want to call MS.
peps1
January 10, 2013, 2:44am
3
Its a trap!
Cominco is wearing a wire........show me your nipples!
K hold on ill put in the code and screenshot it
ok here you go, im serious i need a key
http://gyazo.com/6d7d59524ad5669116b6945149ba7cb7
Do you have a windows xp disk with code? or without code?
