Hi everyone
I am hosting a 4 Minecraft Server for some friends from a PC that is running Mint. I am trying to write a script, making it possible to start them all with one click. It used to work, but after moving the Server-folders around it stopped working an I was not able to fix it. (tho I changed the directory and changed privileges. I don’t know why it woun’t work as I did not change anything at the base code of my .sh files.
So this is how my system is set up->
I use the startServer.sh script to fire up the start1.sh,start2.sh,start3.sh and start4.sh skripts located in my MC_Server folder.
The start1.sh,… files then start the different servers.
As it is, the different terminals (I need 1 terminal per server) start but are not able to load the designated script and there is a error.
startServer.sh (Schreibtisch)
gnome-terminal -e Dokumente/MC_Server/start1.sh
gnome-terminal -e Dokumente/MC_Server/start2.sh
gnome-terminal -e Dokumente/MC_Server/start3.sh
gnome-terminal -e Dokumente/MC_Server/start4.sh
start1.sh (Dokumente/MC_Server/start1.sh)
cd Dokumente/MC_Server/MinecraftServer
echo “Server1”
java -Xmx2G -Xms1G -jar craftbukkit.jar ngui
Sorry I am swiss so everything is in german. But the Error says it can’t find the directory or the file.
Error:
Kindprozess »Dokumente/MC_Server/start4.sh« konnte nicht ausgeführt werden (Datei oder Verzeichnis nicht gefunden)
If I manually tip the code into the terminal it works, like it should, but if I run the script it does not.
What am I doing wrong?
I am logged in as a power user but not root, if this is a issue.
Thanks in advance Janick
