Would this PCI E Wireless adapter work fo my needs
My brother want's a rig and while i can help him with most of it the one thing i struggle with is the Wireless Adapter i know little to nothing about them since i have a wired connection and the AM3+ Motherboard that i picked for him the M5A99X Evo R2.0 has no built in wifi, i could be wrong but i don't think any AM3+ motherboard have wireless built in i may be wrong though. he want's to stream on twitch so the adapter needs to be able to handle that task. Our internet is 100 Down/ 5 Up and it does stream i stream to twitch no problem. This is the one i picked out so far http://www.newegg.ca/Product/Product.aspx?Item=N82E16833704133 it can only handle 450mbps from what i gather which is fine i wanted one with good reviews and was reliable and this is what i found and 50mb does not seem like a big deal. but it show's no mention of the upload speed which is what is most important here. Any help would be appreciated.
Well if those needs include being invisible then I think it should work out just fine!
lol sorry updated it, my bad.
I have one i can vouch it works well.
Thanks, Do you have any experience with it in twitch streaming?
It worked decently for streaming just only at close on the 5ghz. wired is always optimal.
Ok thanks if that is the case i will just have to try and get a wired connection.
