Would this build work?
This is the build I am going to do, I was wondering if this would be a good, functional gaimg PC the parts are:
CPU: AMD FX 8350
GPU: AMD Radeon 7950 MSI TF III OC
Motherboard: Gigabyte GA-990FXA-D3 Motherboard
Case: Bitfenix shinobi black with window
Storage: Seagate SV35.5 HDD
PSU: Coolermaster GX 650w 80 plus certified ATX12V
RAM: 8GB Corsair Vengance (1x8GB)
Cooling: Corsair H110
well it would work but i would do some changes on this.
i would go with a diffrent motherboard, that gigabyteboard is realy crap especialy for overclocking, the northbridge chip will runn extreme hot. i would go with the Asus M5A99Fx pro R2.0 6+2 powerphase digi vrm great mobo its capable to oc the FX8350 to 4.8 ghz without anny troubles. . or if you can afford the Asus 990Fx sabertooth R2.0 8+2 powerphase digi vrm
better psu i choosed for a Lepa 650W 80+ gold
2x4 GB G-skill Ares 1866mhz memory, for dual channel, much better performance then single channel.
1TB WD HDD and samsung 840  120GB SSD. this makes your system boots up much faster, and makes the computer overall much more snappier in windows.
here is my list: http://pcpartpicker.com/p/19dr5
grtz Angel ☺
use pcbulder.com  it you can find reviews and compatiblity problems there
why do you always recommend that asus MOBO? is there any job it doens't do well?
Because Asus Makes the best AM3+ boards thats why. better quality vrm´s
and ofc if you go with the highend FX8350 cpu, then you also wanne have a good and stable mobo
I would recomend it as well. It is just a really solid board.
