I have been looking for VESA mount monitor that can give a similar experience that the Dell business monitors can provide.
That monitor that I am going to use the stand on is the Asus VH238H Black 23" Monitor:
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
There is one product that is very interesting:
There is one review on amazon that says it is good:
The stand is compatible with the mount (100x100 VESA mount), and the monitor weights less than the maximum supported weight for the stand ([Stand supported weight] 17.5 lbs > [Monitor weight] 9.48 lbs).
Has anyone used this stand before? Was it good or bad? Anyone know any stand that is better? Keep in mind that I want to stick with a stand only (for a single monitor) because anything else would be overkill for what I need plus my desk is at a corner, so I don't have a lot of room.
Edit: Here is a slideshow of the monitor
