hey what's going on everyone, i'm looking in to a new pc going to be with X99, but would like some input on it. here's the parts list: http://ca.pcpartpicker.com/user/YOUNGJ2525/saved/z63gXL .
just to let you all know i have most of the parts in my current build. really just look for a CPU, MOBO and ram, but feel free to change what you would like.
don't want to spend more then $1,000 on the 3 parts.
I would go with a cheaper power supply because you aren't gonna need 750W for this system unless you plan to run dual GPU. And use that money to buy a stronger GPU because you can do better than a 760 in this pricerange. If you want you could also use a cheaper motherboard, so I came up witht this:
http://ca.pcpartpicker.com/p/7wJbyc
I chose the 770 for this one but the 280x from AMD is also great value, if you wanna go with that.
I already have most of the in the pic right now. I just upgrading from a am3+ to x99 I just need the mobo, cup and ram. I have the video card, psu, case and cooler. I just don't want to spend more then $1,000 on the 3 parts
