Just wondering with the case there are the set cables pre built in (duh).
If anyone owns this case would you be able to tell me what cables are already attached to the case and where and what they do? Help would be much appreciated :)
You will have cables for your USB 2.0 and 3.0, cables for your front audio and mic ports, for your SD card reader, and power cables for the pre-installed fans. All the information you need about them can be found in your manual.
Cheers man the thing I am worried about is that I also plan on getting a Asus Maximus V Formula which has two USB 2.0 headers. I then plan on getting a H100i which means that will use a USB 2.0 to monitor the fans on it. Then when I looked in to the Switch 810 it looked like like it needed 3 USB 2.0's (might be wrong). If that is all correct would that mean I would have to change case or MOBO?
