Would IT FIT!? (NEED HELP)
Hi guys,
I have the ThermalTake Commander MS-I case but I'm not sure if a Corsair H100 cpu cooler would fit? If it doesn't hwat are other reccomendation for cooling the AMD A10-5800k?
You dont need an H100 to cool an APU even if you overclock it to the hill. I would get a decent air cooler instead like the Hyper212 plus. Those APUs dont put out even nearly as much heat as the 8-core big brother.
aha, okay, how about maybe even a Thermaltake Frio?
