Would i need a RAID card for this?
For my next build I plan to have 2 512gb drives in raid0 and then have 4 3tb drives in RAID10,  will the on board Raid controller be enough to handle this?
prolly need a raid card for the hdd but not the ssd's however if you need it for one you might as well use it for the other anyway just for the performance.
RAID 10, when RAID 5 exists. My sides are in outer space, Depending on your mobo it should be able to run the 2 drives in RAID 0 but I think you may need a RAID card for the others.
spend the $100 on a good raid card
