Would a 4+2 power phase be enough to overclock an 8350?
(I live in the United Kingdom)
I was thinking of getting this motherboard: http://www.asus.com/Motherboards/M5A97_R20/
(and this build) http://uk.pcpartpicker.com/p/HJyS
I was originally going for a 6300, but now I got a copy of windows 7 from a friend, I can afford the 8350.
The 6300 (from the top of my head) uses 95w at the most, stock freq. of course, but I know the 8350 uses about 140ish watts, would a 4+2 power phase be enough to get a good overclock with it? Nothing extreme, using an hyper 212 mind you. I know the more power phases the merrier, after some research.
If you can, point me in the right direction for a better motherboard (preferably asus)
Any help is greatly appriciated.
http://www.gigabyte.com/products/product-page.aspx?pid=3894#ov
or
http://www.asrock.com/mb/AMD/990FX%20Extreme4/
8+2 is preferable
i have the asrock and can get my 1045t to 3.5GHZ easy .. i would highly reccommend either
