I have just got a new Motherboard, Gigabyte z87x - oc force. I will be overclocking and gaming on this machine. I have been reading the onboard sound is not the best compared to some other motherboards.
I have been out of pc gamin and overclocking for 10 years before you wondering why I am asking what are probably stupid questions.
Is it worth getting a sound card and will I notice a difference in sound ? I am using Logitech Z553 speakers at the moment or switching to my main sound system via optical out for 5.1. I will get a headset eventually.
Are there any performance benefits having a sound card instead of onboard ?
If I should get a sound card, are creative sound cards still a good option or is there something better? If I am going to get one I will be looking at spending £30 to £70, unless there are some good reasons for spending more.
if your usage is literally just gaming then I would probably recommend just going straight for a good set of surround headphones with a built in audio solution (plugs into usb), they are convenient and a much cheaper option, and the quality can definitely be decent enough for gaming, especially as in gaming good 3d audio positioning tends to make makes more difference than audio fidelity.
if you want audiophile grade sound however (for epic grade headphones and speakers) then you basically have to go with an external DAC. But it is unlikely you would perceive much, if any, difference on the speakers you list. Audio fidelity has a steep price gradient, you have to spend a lot and upgrade your whole signal chain to get really feel the difference, so unless you can really take advantage of that difference then its probably not worth it.
SeptimusDave, that's an excellent point, that everything in the chain has to be good in order to get good sound.
My personal experience is with loudspeakers, not headphones. One can get an immediate and obvious difference in sound -- in terms of accuracy it's a significant improvement, but you can hear a difference -- for less than US$150 not including speakers. I'm using Jamo C403's.
For people with the highest standards and needs, there's the ODAC and O2 headphone amp. I'm a mere mortal and impressed with a US$30 DAC plus a US$70 low power loudspeaker amp.
Like the others mentioned, with those speakers, you are unlikely to find any gain in getting a sound card, simply because the speakers are not capable of putting out any good sound. However, if you plan on getting a good pair of headphones or speakers, then right now the best recommendation I can make is the ASUS DG/DGX: great quality and cheap (~$40). As far as speakers go, the best computer speakers for the price are going to be studio monitors first, or the Creative Gigaworks T20 or T40 speakers second if you don't have that extra inch or two on your desk for studio monitors.
So for about $100-150, you can have a fairly nice sounding audio setup for your computer.
My problem with people recommending soundcards for speakers is that a DAC can usually be obtained for the same price and often lower. If anyone truly believes a soundcard can benefit speakers over onboard, an external DAC will exceed the supposed benefits of any soundcard.
