Workstation Rig
Hey everyone!
Im attempting to build a workstation that can be powerful enough to monitor a ton of data from social networks and be able to render images and videos as fast as possible. Its for a new company I'm working for and I cant seem to come to any set conclusion as to what to go with hardware wise. The only thing I do know is that I want to stay Intel. I have a budget of 5-6 grand for the main workstation that I will be running Photoshop/Dreamweaver/Final Cut and the tracking software on. Its also going to be my personal computer as well since all my time will be spent on it, so it will have my games on it (perks of being the owners friend haha) so I'd like it to be able to run games pretty damn well. Any help will be greatly appreciated!
Thanks!
Do you need any peripherals?(OS, keyboard, mouse, monitor, etc)
Do you plan on overclocking?
yes, preferably a 2-3 (depending on price) monitor setup. and as for overclocking, if I can get a closed loop water cooler for the cpu thats not dumb expensive (I dont want to use the entire budget, Im not greedy haha) then Id go for it
Since noone has helped you, I tried to give you a good starting point.  I am still learning the LGA2011 platform's features, and I would like some verification from other forum members before you go on and purchase this.
http://pcpartpicker.com/p/3CSvg
I do believe Adobe can take advantage of CUDA acceleration.  However, for productivity, you may only be able to use one card, since SLI is created for gaming.  You may also want to try and pick up a third monitor if you want to do NVIDIA Surround(perhaps 3x 1920x1080 monitors).
