Workstation PC?
So I'm quite familiar with gaming PC parts and how to build one.  But what about workstation only pcs?  What kind of parts do they need that are different?  What do workstation apps take advantage of that games don't?  What is a good budget for a workstation? How would a workstation Pc do in gaming?  What is the difference between a gaming GPU and a workstation GPU? What are good workstation GPUs? What are good workstation Cpus?
I'm just looking for general information to get a better understanding in workstation pcs for my own general knowledge.  I'm not looking to build one anytime soon.
Thanks!
all of that depends on the programs it needs to use, a workstation made for solidworks and a workstation made for premier will be very different
when someone asks for a workstation you don't just go off some general guidelines, you need to know what programs they will be using and then once you know that you can look up what types of things those programs take advantage of, does it need a dozen weak cpu cores or does it need 2 powerful cpu cores? does it need opencl, opengl, or cuda acceleration? does it even support gpu acceleration? are only workstation class gpus supported? does it see a noticeable difference between a workstation and gaming class gpu? does it need certified ecc ram?
all of these and more are important questions that need to be addressed on a program by program basis
Oh Ok thanks.
