Hello,
Sorry for long post, but i like some feedback on the components i am putting together.
Boss has given thumbs up for a new rig. [location Europe, pricing < ~2500€]
Good thing Wendell is doing a 4 parter in this domain right now
Basic work:
- Running linux (probably Arch/Manjaro distro)
- programming & compilation
- from embedded, to HPC [C, C++, java, kotlin, python, really just about everything…)
- i should spend most of my time in research of parallel & distributed systems
- in future we do plan to branch our algorithms to GPU / accelerators, but this can be upgraded later
- running tests & builds in background
- Virtual machines (windows, linux)
I want it to be quiet, hassle [driver] free and able to turn RGB off!
I do not need crazy amount of PCI lanes or memory, so HEDT is not necessary
Based on that, i was aiming for upcoming 3950x:
CPU - 3950x (prefer over 2950x due to cache)
- BeQuiet Dark Rock Pro 4 cooler [~30€ cheaper than D15, is it ok?]
I want it to be quiet, but not keen on AIO for long term
MB - x570 board - targeting around 350€
- sufficient vrm for 3950x, 4x dimm slots, 2x ethernet, bluetooth 5.0, at least on pci4 m.2
- nice to have: second m.2, > 4 Sata ports, thunderbolt 3,
- Upcoming x570 creator looks ok, might be quite expensive
also colleague can not set WOL on x299 taichi, so i’m a bit skeptical about asrock support
Here is Geizhals link to filtered MB https://bit.ly/2Pemq3i , Any opinions about these?- Asus ROG Strix x570-E Gaming
- AsRock x570 phantom gaming x
- MSI MEG x570 Ace
- Gigabyte x570 aorous master
- Asus ROG crosshair VIII Hero [wifi]
RAM - 2x 16gb of 3600Hz (are timings still important? Best P/P option?) Would like to leave 2 slots empty for future upgrades if need be.
GPU - Radeon 5700 / 5700 XT
- 1x4k + 2x fullHd outputs
- little to no games, but might use for compute (mainly fp 64)
- RDNA seems to be relatively ~OK~ for computing
- vega 64/56 seems a bit better for compute, but long term support?
- will probably go OpenCL / sycl route, due to non-proprietary nature, rather than CUDA
- Vega 7 seems to be EOL (16gb and large fp64 seem very, very, very enticing though…), but is still a ~bit more expensive
- would like to avoid nvidia due to bad experiences with their drivers
- if p/p is better, than nvidia is still an option
SSD - [Corsair MP600 1tb SSD] or [Gigabyte aorous Gen4 1tb] or [Adata PXG gammix 1tb], whatever will be cheapest when buying
HDD - 2-4TB HDD for temporary backup and work files (again, whatever will be cheapest)
Case -BeQuiet Silent base 601 (should be quiet and still provide enough airflow, if i read correctly)
PSU - 750W (80+, modular)
Is there anything that seems wrong with this build? I’d really appreciate MB and RAM suggestions.
I feel like for GPU even rx570 would be enough, i’d just like longer driver support…
Thanks in advance for your input
