Hey Everyone,
It's time for my upgrade/rebuild of my current system and money is tight now so I need some advice.
current system:
Windows 10 pro 64-bit
Custom loop water cooling. xcpc 5.25 bay pump/res and a 240 rad
i7-3820k clocked at 4.6ghz
ASUS sabertooth x79 - has many bad usb ports as of now
EVGA GTX770 SC - stock and having issues
16Gb Corsair 1866Mhz ram
New Corsair RX750 power supply.
OCZ Revodrive PCI-e SSD ( this thing sucks big time: ie.. 200Mb/s transfers)
and various decade old HDDs. (ie: some WD velociraptor 500 gb HDDs and some even older HDDs)
Planned system
custom loop water cooling
i7-6800k probably only OC'd to 4Ghz
Asrock x99 taichi - iffy on this choice.
32Gb corsair vengence 2133 ram the c13 kit
Samsung 950pro m.2
and a few Samsung 850 EVO SSDs one for work and one for games.
GTX1070 of some kind
keep my existing PSU
Also, will be ditching my 21:9 displays for a 4k HDR display. I need that resolution bump and better color reproduction. and 4k gaming with no AA would be nice. Though I'll prob game at 1440p to gain or keep a 60+ fps.
So, I already picked up a Fractal Define S case, a 4Tb HGST HDD for 99 bucks for my mass storage, a EKWB D5 res and pump combo, and a EK coolstream se 360 rad, but i might exchange for a 140 variant for top mounting in the case.
note: I will be using soft tubing because the only time i look inside the case is when i clean it.
I am looking to get more performance ASAP. I do a lot of Adobe suite work and work in Rhino, Solidworks, and Alias. Most of which currently has been Alias and Photoshop work. Gaming wise it's mostly WOW, LOL, Vanishing of Ethan Carter, Shadow of Mordor, Skyrim with mods, ESO, but no current AAA titles. Possibly looking at GTA V and Rise of the Tomb Raider and whatever the next Assassin's creed game comes out.
So my questions for anyone with knowledge of the software or hardware,
1- are there any issues with the planned config? I'm unsure about the reliability of that Asrock Mobo.
2- Is the RX480 enough ( with possibly a second rx when I can get one) or should I stick to getting a 1070?
3- any general hardware suggestions?
With the Intel 600p SSD's around the corner and Zen in 2017... should I bother with the Samsung SSD's and getting the 6800k?
I will be getting parts when I can so I'm not in any rush, though storage and GPU are the first upgrades on my priority list before moving to the new cpu/mobo.
Thanks for the help in advance
