Workstation for Autodesk Inventor
I am starting to look for an upgrade of my CAD workstation. The CAD programs I am using is Autodesk Inventor and Autocad, nothing else. I also use Adobe Photoshop and Corel Designer. The programs are usually used together for example when analysing large X-ray pictures, where both Autocad, Inventor and Photoshop are used. It will not be used for gaming at all. I am running Windows 7 64 bit.
I am now using (old rig)
Graphic: Nvidia Quadro 4000
CPU: Core 2 Quad Q9700
Memory: 24 Gb 1600 Mhz
Hdd: Two SSD, one for the operating system and one for data (Samsung 840 EVO Series MZ-7TE1T0 1T)
As of now with my old rig I got some severe performance issues:
A change in the 3d model requires an update time of 20-60 min of the 2d drawing when using large assemblies. This process is not parallelized and use only one of the CPU cores.
Memory limit, when doing FEM analysis on models or when running several programs at the same time I hit the memory cap.
Slow graphic performance in 3D when using large models.
This is the new rig I am thinking about, I only need new graphic, motherboard, CPU and memory.
1st Graphic: Since Inventor uses DirectX I do not need a workstation graphic card, they are slow compared to “gaming cards”, se for example: http://www.tomshardware.com/reviews/radeon-r9-290x-hawaii-review,3650-32.html . So I am thinking about the:
XFX Radeon HD7990 Triple D 4xDisplayPort 6GB (in Sweden 1075 – 1383$)
2:nd CPU since some parts of Inventor is not well parallelized and some other parts are I do not really know what kind of CPU would be best? Can’t find any performance charts of this. So maybe this one:
Intel Core i7 4930K 3,4GHz Socket 2011 (In Sweden 691$)
3:d Motherboard:
Asus Rampage IV Black Edition/AC4 (In Sweden 614$)
4:th Memory. I do need 64 Gb of it:
2x Crucial Ballistix Sport VLP DDR3 PC12800/1600MHz CL9 4x8GB (In Sweden 891$)
What do you think?
personally i would go with 2 r9 290s and water cool it, though i don't know your market so they may not be an option with the litecoin craze. other wise i like your build it offers alot of CPU and graphics power as well as all that ram to work with for your work applications.
Thanks! But I think it is premature to use Crossfire in a workstation, se for example:
http://www.tomshardware.com/reviews/dual-graphics-crossfire-benchmark,3583-10.html
And it looks like Inventor doesn’t support dual graphic cards:
http://www.mcadforums.com/forums/viewtopic.php?f=5&t=12719
the 7990 is essentially crossfired 7970s on a single card. You should run into similar issues if there are any.
Dont look at crossfire or SLI. Autodesk does not officialy support it. Also Autodesk is heavily one sided with Nvidia. While performance is better with AMD in many cases, Nvidia is supported and well you will have less problems.
So maybe an Asus GeForce GTX690-4GD5 4GB then. Will that card support 4k monitors? I am thinking of getting the Dell UltraSharp 32 UltraHD Monitor later on.
after using a Quadro 4000 u might be SERIOUSLY joking when u say "So maybe an Asus GeForce GTX690-4GD5 4GB then" how long have u been working with this current configuration & how long have u been using Inventor, r u a professional or a freelancer ?
do u realize what u have now is a "workstation" & its something i can only dream of, if u consider upgrading (only GPU) then u can easily upgrade to the new K5000, but i don't know how is a 4000 not enough for u while using Inventor
btw i work with similar but a lot different in the genre of application software like Autodesk 3ds Max & Maya
i think u might have already seen the link i'm posting below, but if u haven't then u must have a look to at least understand the general setup that u might be requiring as per your specific needs
http://www.nvidia.com/content/quadro/autodesk-suites/pdf/Inventor-Solution-Overview-Nov13.pdf
Been using Inventor since ver 4 and Autocad for about 20 years so I guess I am an professional...
Not joking, working with quite large files and the graphic is not fast. According to Tomshardware a GTX690 is about 4 times faster then a Quadro 4000 in Inventor. As I understand it it is because Inventor and Autocad uses DirectX.
Once again according to Tomshardware a Quadro 4000 is 5,6 times faster in Maya compared to a GTX690, the same is probably true for 3ds Max as well. But I am only using Inventor and Autocad and want to optimize the system for that.
Maybe there are some other performance comparisons between Quadro and GTX cards for Inventor but I can't find anything.
Yep seen that, that is the reason I bought the Quadro 4000 in the first place. But now when I am searching on the net the only performance comparisons I can find clearly shows that for Inventor and Autocad a GTX 690 or a Radeon 7990HD clearly outperforms even a Quadro K5000, they are more then twice as fast for half the price!
u know what i really don't understand how on Earth r u even comparing a NVIDIA GeForce GTX 690 or an Radeon card to a Quador 4000 if u would have compared it with a K600 or a K2000 i would have believed u BUT u say a GAMING card outperforms a HIGH END workstation card, then i really don't know what to say, i've worked on the Dell Precision workstation series for a short period it was equipped with a Quadro 2000 which is a much lower card compared to the massive Quadro 4000, & i've tried heavy (in terms of resolution as well as particle density) fluid as well as particle simulations (FumeFX & RealFlow) on it & it was significantly faster then any gaming card i've ever worked on before, even rendering out a decent amount of Hair & Fur in Maya was no problem, so i can never believe that a GPU meant to handle such applications cannot outperform a "690" in particular
urfiredup, He is right. The only reason why we have work station cards is because their designed to be stable. Though I do not recomend the 690. It is an SLI card. It has 2 GPU's on it and I believe autodesk software will only see 1 GPU. I would say grab a titan. It will out perform the quadro 4000 and the 6gb's of ram you will probably need. if you want best performance, the 780 ti but you lose out on how much you can have on the screen at one time.
Rudster the Titan is no doubt a mighty card with 2688 CUDA cores, but after searching the web about this & asking a few people around it just led to more confusion, i'm pretty sure i don't have much to say on this coz (A) i'm not an Autodesk Inventor user, i do Autodesk 3ds Max or Maya or Adobe After Effects stuff & (B) i don't understand
Please don't get multiple GPUs or cards with multiple GPUs for workstation purposes.  Most of the softwares can only make use of one GPU anyway.  SLI and Crossfire are for gaming.
I would suggest the GTX 780ti.  More CUDA cores than the Titan, and cheaper.
I have read that Inventor 2014 now uses multiple graphics cores, see for example:
http://inventortopix.blogspot.se/2013/03/inventor-2014-whats-new.html
Quote
"The graphics system now uses multiple cores to provide the best possible performance."
End Quote
Other links I found about this:
http://forums.autodesk.com/t5/Inventor-General/Inventor-2014-What-s-New/td-p/3815150/page/7
The workstation / gamer card debate has been going on for years, and the truth of the matter depends on the graphics API of the software which determines what hardware is best suited.
When it comes to Inventor my experience has been that the price per performance ratio between workstation station and gaming cards is simple.  Inventor uses the DirectX API and there for gaming cards provide adequate performance for their lower price point.
I back this opinion up with many years of practical & professional Inventor experience, as well as having worked for an Autodesk reseller as a Application Specialist.  But if you do not want to take my word for it, try this PDF what Quotes one of the Inventor Graphics developers "Norbert" as he explains how Inventor uses DirectX and the logic behind the transition Autodesk decided to make when moving from OpenGL to DirectX.
Ultimately, we want to provide an Inventor product that is of the highest quality in terms of graphics _and_
that is affordable for a _wide_ range of budgets. For example, if you are no longer _required_ to spend
$1000 to $2000 to simply have graphics HW that works, but can instead purchase a $100 to $350 game
card .
http://forums.autodesk.com/autodesk/attachments/autodesk/78/442801/1/autodesk_inventor_opengl_to_directx_evolution_788.pdf
Also when Autodesk said "The graphics system now uses multiple cores to provide the best possible performance." they were referring to CPU not GPU cores.
I hope this helps in your decision.
much necro.
but ok.
NECRO. LOCK.
