Workstation / Fluid or aero simulation
2500€ (i know my build is above that-should be pushed down to 2,5k)
Germany-Dont like shipping
No preferred retailer
Nescessary but added spereately
Fluid simulation / Render
No overclocking 24/7capability Appreciated
No custom watercool loop but a closed one would be nice
No New OS
Rendering/Editing/Work is done in NX 10.0, NX Nastran, Ansys 17.0, Blender Photoshop, After Effects, Illustrator (basically the whole cs 5 suite, upgrade to newer versions may happen
https://www.mindfactory.de/shopping_cart.php/basket_action/load_basket_extern/id/7814472218bec94b1e325086fad93c17fa5b4ce2067965588d5
Would this Processor be better ?: http://www.mindfactory.de/product_info.php/Intel-Xeon-E5-2603v3-6x-1-60GHz-So-2011-3-WOF_976627.html
Feel free to change everything
I have the same MB so maybe I can give some good info.
  1. The CPU in your main build doesn't look like it can be ran in a dual CPU setup per Intels specs. You may want to look into if there is a workaround but Intel lists it as a 1 CPU per board max
  2. ECC ram would be a great upgrade if your doing any type of serious work.
  3. A closed loop is not necessary for this kind of application. Something like the noctua nh-u14s works great because it still provides the airflow you need for your ram. Remember these kinds of boards are setup for airflow in a certain direction and your case fans may not be able to deliver that unless you run them extremely fast.
  4. The 900d is really expensive for what you get. If your looking for a cheaper solution the fractal xl fits this board well.
  5. The last thing I can think of is make sure your PSU has leads that are long enough to power this board. Lots of PSUs have shorter cables and they wont work with this huge board(the power is along the top of the board). Either pick up extensions or make sure the manufacturer lists the specs for length. Also it needs to be able to power 2 CPUs lots of PSUs dont have 2 8pin cpu connectors.
