This workstation will be used for editing in premiere pro and for compositing in after effects. I am planning on adding another 970 to the build later, and also upgrading the ram to 64gb and the processor to a 5930k or 5960x.
You can get this 3TB Hitachi drive for around the same price as the two 1TB Blues http://pcpartpicker.com/part/hitachi-internal-hard-drive-0f12456
Personally, I don't think there's much of an advantage of having 32GB over 16GB of RAM, unless you're rendering at 4K. If you decided on going with 16GB, you'll have enough money to upgrade to a better motherboard/higher capacity SSD. I'd recommend this motherboard http://pcpartpicker.com/part/asus-motherboard-x99pro with the 250GB 840 Evo.
I'd go with an NH-D15 over an H100i, but that's just personal preference.
AX760 is $119.99 on Newegg http://pcpartpicker.com/part/corsair-power-supply-ax760 Better efficiency than the evga one.
