Workspace per monitor
Is there something I can do for having my workspaces been independent depending on the monitor where my mouse is? I’d like to use the same hot-key, and if I’m on the right monitor it only moves that to a different workspace. Then I go to another monitor, and it moves to another works space.
Just installed Ubuntu 18.10 today so I’m pretty noobish. I’ve seen things like i3, Awesome, and others but not sure if that’s what I should be looking at?
This depends on the DE you’re using. is it vanilla Ubuntu?
Yeah. Was using PoP OS for a few days, but decided on Ubuntu 18.10.
If you install gnome-tweaks there are a few things to adjust about workspaces. I’m not sure what you want to accomplish exactly.
Thanks @nickelghost. I have gnome-tweaks installed but that’s an all workspaces or primary monitor only setting. I’m trying to do Only the right monitor moves workspaces or Only the left monitor moves workspaces - while the others do not.
Any update on this?
There used to be Compiz for that but it’s deprecated by now.
Then I heard something about “This is not FVWM standard” without reason why.
Yet Mac had all this implemented long time ago.
