Working out on a pc I should build
This is the link: http://pcpartpicker.com/p/2dYp8
Tell me if there is anything I should change. I would like to stay under the 2 grand mark though.
Few questions;
>Why ivybridge?
>Why such a small screen & 1080 res with all the horsepower of xfire?
http://pcpartpicker.com/user/deejeta/saved/326d
>No storage?
In my opinion you should get a single gpu like gtx 780, r9 290/290x or even gtx 780ti since crossfire can cause some problems and you would still be under the 2000 mark since you could swap out the powersupply to a 750w
I would also get a single GPU solution, as they are usually more stable and such.
Someone could probably whip up a 2011 build with that budget.
No Storage? Or reusing old?
And only 21.5" Screen? You cold get a decent 23 or 24 inch for less money.
