Working on my steam box
So I've spent today attempting to turn my Bitfenix Lan party build into a steam box, all has gone pretty well apart from a few thing. I was wondering if any of you guys could maybe help shed some light on how I might go about fixing some of these issues.
1. I have non-genuine version of windows and I normally use windows loader by Daz to fix this, however. Before rebuilding the PC in order to transform it I formatted the hard drive so I could start from scratch, now that all whent fine untill I tried to use windows loader. It says that my partition table is unsupported and on the faq it states that the only way to fix this would be to conpleatly format my hard drive, therefor deleting windows and ecerything with it. Is there a way I can get around fromatting my HHD, I only want to do this because the only thing stopping windows from booting directly into big picture mode is windows telling me off because its not genuine.
2. I want to change the boot logo into a steam gif to make it look more professional, but I can only find programs that let me load .bmp images, does anyone know of a program or a way to make it a .gif?
3. I want to use my ps3 controller to navagate the top menu but I need a program called motioninjoy to make the controller work, I have put it in the startup folder but I wants admin rights to run, meaning I need to use a mouse to authorise it, is there a way to make this automated
4. If I want to download a program not on steam I currently have to open task manager via ctrl alt del and open a new task, is there a way to make this process into a batch file or maybe a .exe
and 5. Where could I get a 3d metal steam logo to slap on the side of the case?
Bump
Bump
Bump (Sorry I need answers
for the logo, i think brennen can make you one if you give him some detentions.
These are only my recommendations... take it for what you will, if anything it's an extra bump
1) Use some form of linux (Unbuntu for example) as your OS instead of a Windows if you're not willing to shell out $80 or so. Steam works pretty decent on Unbuntu and Steam OS is going to be a form of linus anyways, so this could help you get use to the basic backbone. If you want to ignore that completely, check Newegg or any other retailer for Black Friday sales for cheap Win 7 copies.
2) I don't remember how to do this, but I remember seeing something in a youtube video so that you can do this. Just keep checking around, since you don't technically need a program; just a relatively simple hack will do.
3) No clue, sorry.
4) No clue, sorry.
5) There are a variety of options you have. Either keep looking on the web (maybe etsy has something, I don't know), or you could try to find a local machine shop to crate one for you (you're in England so that might be difficult as well), or lastly, make one yourself. The easiest way to make one is to buy a small amount of aluminum or some other metal that is fairly soft and you can just use a hacksaw or a jewelers saw. The softer the metal, the easier it will be to work with (which is why i do not suggest steel). Also, you should be able to buy a jewelers saw and some blades for it fairly cheaply if you look around. This will also give you a good chance to work with you hands and become more self-sufficient.
Hopefully, my comments give you some ideas at least.
Motioninjoy is malware, I don't trust it anyway. Try this instead, I use it and it doesn't require admin permission
http://forums.pcsx2.net/Thread-XInput-Wrapper-for-DS3-and-Play-com-USB-Dual-DS2-Controller
Thanks for the link, I don't think motioninjoy is malware as I have seen a lot of major youtubers using it. But hey if this works then its better than MIJ strait off the bat
