Budget: $800
Gaming: very lite (spider solitaire)
Rending Software: Photoshop, Corel Draw
peripherals: Logitech Wireless Combo MK270
http://pcpartpicker.com/p/2cLNJx
Building my Friend a small work computer on a budget.
Far as I can tell it's all Compatible. Any Suggestions would help me pull the trigger on the order.
plan on using Windows 7 pro. No overclocking
Thanks for any advice.
Sorry... Help me out here...
Why are we spending 180$ on a case and PSU and end up putting 6800K inside?
I'd rather go with larger system as a size, cheaper case and FX6300 or FX8300 or something... I am not even sure how well multithreaded Photoshop and Corel Draw are. If they are not well multithreaded, you will be way better going for i3 or something...
Why?
here, you'd probably be fine with even just like an i3 and spending that money on 1TB of SSD storage
Motherboard has built in wifi, got a bit higher end hard drive as it seems that it's meant to be portable
PCPartPicker part list: http://pcpartpicker.com/p/VjxvLk
Price breakdown by merchant: http://pcpartpicker.com/p/VjxvLk/by_merchant/
CPU: Intel Core i5-6500 3.2GHz Quad-Core Processor ($194.99 @ SuperBiiz)
CPU Cooler: Cooler Master Seidon 120V 86.2 CFM Liquid CPU Cooler ($49.99 @ B&H)
Motherboard: MSI B150I GAMING PRO AC Mini ITX LGA1151 Motherboard ($109.99 @ SuperBiiz)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory ($61.88 @ OutletPC)
Storage: A-Data Premier SP550 240GB 2.5" Solid State Drive ($56.97 @ NCIX US)
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive ($73.89 @ OutletPC)
Case: Cooler Master Elite 110 Mini ITX Tower Case ($38.99 @ SuperBiiz)
Power Supply: Fractal Design Integra M 450W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ Newegg)
Total: $636.69
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-04-11 18:36 EDT-0400
Went with 6800K for the APU an clock speed.
My Friend Has a small crap Dell an wants to keep the size small.
Trying to stay with amd to keep cost low.
You'd be better off with an i3 or i5, unless you just wanted something really cheap with like an A8 7650K
The cost is set... We are talking performance here... If we can squeeze better for the same price, you and your friend may want to go larger...
Hi... Um... I am sorry, i know lately i am a bit annoying, but this cooler have a lot of issues. Noise being one of them and pump failure being the other often encountered one... The one with the square pump is the bad one... There is another one with a round pump... It does not have that many reported issues...
Probably an H60 then
http://pcpartpicker.com/part/corsair-cpu-cooler-h60cw9060007ww
Far as the other build goes, it might maybe make some sense to go with an A8 if he doesn't already have a large display to work on, or a color accurate display
PCPartPicker part list: http://pcpartpicker.com/p/Zb9HVn
Price breakdown by merchant: http://pcpartpicker.com/p/Zb9HVn/by_merchant/
CPU: AMD A8-7670K 3.6GHz Quad-Core Processor ($94.99 @ SuperBiiz)
Motherboard: ASRock FM2A88X-ITX+ Mini ITX FM2+ Motherboard ($89.99 @ Micro Center)
Memory: Mushkin Essentials 16GB (2 x 8GB) DDR3-1600 Memory ($49.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($47.77 @ OutletPC)
Total: $428.69
Generated by PCPartPicker 2016-04-11 18:45 EDT-0400
I'd go w/ a phanteks enthoo evolv itx for $60. Better clearance for a tower cpu cooler (liquid is very overkill and air is quieter and lasts longer, just a fan replacement every now and then). other than that i have no issues w/ your build.
