Wolf's PC options
So right now, I have an ASUS G53SW-XA2 that I am gaming on, and a Macbook Pro that I am selling. Overall, really love the laptop, but it is a love-hate thing. I have an empty Fractal Design case from my previous gaming PC, and one thing I loved about the desktop is how easy it was to work and replace parts on it. Also loved the faster speeds, better display, mechanical keyboard, and everything else that normally comes with having a desktop. I love the laptop for being portable when it comes to LAN parties, and that is really it, but it is a huge convenience.
The combined total for both laptops I figure is about $1200, so that gives me a budget of $1200 to either upgrade the laptop for something newer, or build another desktop. Here is what I am thinking:
AMD F2 Gaming PC
AMD FX Gaming PC
AMD G750JW Laptop
Intel. I've said this many times. If your budget is over $1000 U.S, it makes absolutly no sense to go with AMD cpus. So I recommend something like this:
http://pcpartpicker.com/user/Hagame/saved/2vU6
That fm2 build is a joke i hope. your fx build is good.
Should of stated, I have a 128GB SSD already as well in the laptop.
Question though: Why would I want to spend $100 more for a CPU that in gaming will not perform any better, $7 more on slower RAM, and take a GPU that is $50 cheaper that is slower on a gaming PC?
Because the 4670k IS better than a 6350, and putting in a top shelf GPU with a low end CPU makes no sense. And as for the ram, my bad. I'm sorry.
The faster RAM wouldn't make a difference in gaming, unless you're using an APU. For editing, lower CAS is preferred, and Haswell doesn't like high frequncy RAM. So, the 1600 speed would actually be more appropriate for the Intel build, at least. The Intel build is probably the better that I have seen in this thread, if I am honest. AMD offer more value for money, but the FX6300 can be quite a weak CPU at times, particularly in CPU intensive games. Slap an 8350 on that motherboard, and you're golden. I'd get the 7950, instead of the 760, though. Can easily overclock to the speeds of an overclocked 7970
you know what, I haven't made a budget build for the forum in a why
*cracks knuckles
lets see what I can do
Why spend $200 on a 8ms 1080p monitor for gameing when you can buy 5ms 1080p monitors for less than $100 or a 2ms asus for $150? i know its a ips but still $100 extra for a ips for 60fps gameing?
The FX build is pretty goddamn good. The only thing I could suggest is if you're going with AMD, try to get an 8 core processor. We are already starting to see the shift in gaming to be optimized to use more cores, and the 6 cores are really suffering.
http://pcpartpicker.com/p/1KVLM
And you can fit it in your budget with some minor modifications
+1
I previously had that monitor, and it was impressive. Response time isn't everything, as input lag is also a factor, and the Dell has that in spades above everything else. Plus the color shift on TN panels bug me like no other...
Or for the full 1200, you could make this piece of insanity
http://pcpartpicker.com/p/1KW11
AMD is fine but nothing but shitty mATX boards, this is a lan machine so I needs to be smaller
if you need a monitor take out the SSD and opt for a cheaper cooler if you're not going to overclock
also Logan got a pretty shitty CPU from intel so his haswell chip needed a ton of voltage, haswell undervolts like a beast
if you think rosewill only makes shitty PSU then you have 60 Green/capstone/fortress series PSUs I've personally used and a 5Ghz 4670K on 1.28v to answer to
