First of all, this is not about any downgrade but to improve performance&visuals through out the game.
(those are my own settings, and my own opinion)
Make sure you're running latest GPU drivers (both NV & AMD)
1.06
Base remain unchanged.
Every time you upgrade all those tweaks are removed with default settings.
Always make backups before editing files.
*** Version 1.07 is pretty much the same except user.settings, please find below attached user.settings
http://pastebin.com/dwpBMhqD (outdated)
http://pastebin.com/HbLjesFZ (Stable old ~WIP~)
http://pastebin.com/yk31MxhC (current Stable ~WIP~)
**** 1.07 brought plenty of new settings, its going to take me while to look at them all.
First place owners of Nvidia GPU's have to look at (amd owners of 7970, 8970, 280x, 270x, 285 can edit present)
The Witcher 3 Wild Hunt\bin\config\performance.xml
Edit file with notepad or similar one.
Find your GPU
1) Remove 'fpslimit="30'.
2) Edit preset="X" and change X to "3" this will allow for higher quality textures, draw distance etc.
\The Witcher 3 Wild Hunt\bin\config\base\resources.ini
FileQueueSizeGame = 250
FileQueueSizeLoading = 700
MaxRequests = 45 [50 is max, and with 50 or over you might have crashes]
(bigger faster loading)
MaxCompressedBudget = 10
MaxUncmpressedBudget = 240
MaxUncompressedBlocks = 4096
How to improve performance of hairworks overall in AMD GPU's (not that i personally feel like there's need)
(this will also decrease quality and amount of hair)
Inside your AMD Catalyst Control Center
Gaming > Create custom game profile, or use default (up to you)
Look for Tasselation options "Maxiumum Tasselation" and lower it. (2x is lowest, 16x is a middle ground, 32x looks good, and is pretty much same as 64x)
Warning this will fork it out further beyond ultra.
\The Witcher 3 Wild Hunt\bin\config\base\rendering.ini
AllowMSAA=false [keep false, doesn't work]
MaxTextureSize=3048
MaxAtlasTextureSize=3048
MaxCubeShadowSize=1024
MaxSpotShadowSize=1024
TextureMemoryBudget=3500
TextureMemoryGUIBudget=180
TextureInFlightBudget=320
TextureStreamingDistanceLimit=440000.f
TextureStreamingReduceGameplayLOD=true
UberSampling=0 [keep at 0 or 1 = disabled, doesn't work at the moment]
DynamicDecalsLimit=60
MeshRenderingDistanceScale=4.0f
MeshLODDistanceScale=0.0f
TerrainScreenSpaceErrorThreshold=1.6f
TerrainErrorMetricMultiplier=6
GlobalOceanTesselationFactor=64
UseDynamicWaterSimulation=true
UseHairWorks=true
HairWorksAALevel=8 [lower this if you have decreased hardware performance in hairworks]
TerrainReadAheadDistance=600.0f
MeshLodGameplayDownscale=0
CharacterLodGameplayDownscale=0
DecalsHideDistance=100
StripeHideDistance=120
SwarmHideDistance=400
DimmerHideDistance=260
DecalBudget=200
~ Optional 1.07 -- for AMD performance ~ Might not work, and break your configs... ~
Remove Following lines from user.settings (it hinders performance, without them it uses default settings like in 1.06)
HairWorksGlobalWidthLimit=
HairWorksGlobalStrandSmoothness=
HairWorksGlobalDensityQuality=
HairWorkstGlobalDensityLimit=
HairWorksGlobalDetailLODFactor=
Keep only
HairWorksLevel=2 - only if you want nice hairworks to work that is.
\The Witcher 3 Wild Hunt\bin\config\base\visuals.ini
[will take longer to load if your gpu isn't fast enough]
MovieFramerate=60.0
After change of this file I recommend making it read-only as full screen mode is buggy sometimes and it will switch to borderless, this way you don't have to come back and change settings again -> each time you update you need to make writable again...
C:\Users[username]\Documents\The Witcher 3\user.settings
VSync=false
FullScreenMode=2 [many people will have 1 = borderless, this decreases performance dramatically]
VSyncThreshold=0
SpawnedLimit=200
cvMaxAllowedLightsShadowTime=3
cvMaxAllowedGrass=60000
cvMaxAllowedDecalsDynamic=20
cvMaxAllowedDynMeshes=107857600
cvMaxAllowedChunksSkinnedTime=3.5
cvMaxAllowedTrianglesSkinned=100000
cvMaxAllowedLightsShadow=5
cvMaxAllowedActiveEnvProbesTime=0.3
cvMaxAllowedStatTextures=514572800
cvMaxAllowedSpeedTree=5000
cvMaxAllowedLightsNonShadowsTime=0.2
cvMaxAllowedChunksStatic=1500
cvMaxAllowedTrianglesStatic=500000
cvMaxAllowedHiresChunks=25
cvMaxAllowedDecalsDynamicTime=0.5
cvMaxAllowedLightsNonShadows=40
cvMaxAllowedChunksStaticTime=1.5
cvMaxAllowedChunksSkinned=400
cvMaxAllowedApexDestroTicked=40
cvMaxAllowedStatMeshes=409715200
cvMaxAllowedHiresChunksTime=0.2
cvMaxAllowedApexTickedTime=0.5
cvMaxAllowedCharTextures=209715200
cvMaxAllowedParticlesCountTime=0.2
cvMaxAllowedParticlesCount=2000
cvMaxAllowedGrassTime=1.5
OcclusionQueryAdditionalMemory=20
cvMaxAllowedDecalsSS=160
GrassDensity=3400
DecalsSpawnDistanceCutoff=20
TextureStreamingHeadsDistanceLimit=20
GlobalOceanTesselationFactor=128
TextureStreamingCharacterDistanceLimit=70
CascadeShadowFadeTreshold=1
CascadeShadowDistanceScale2=1.5
TextureStreamingDistanceLimit=60000
MaxCascadeCount=4
TextureMemoryBudget=2400
CascadeShadowDistanceScale3=1.5
ScaleformTextureUnstreamDelay=2.5
DecalsChance=1
HairWorksLevel=2
MaxTerrainShadowAtlasCount=4
TextureInFlightCountBudget=12
TerrainErrorMetricMultiplier=4
CascadeShadowmapSize=3072
CascadeShadowDistanceScale0=1
MeshRenderingDistanceScale=1
CascadeShadowQuality=1
CascadeShadowDistanceScale1=1
LimitFPS=0
GrassGenerationEfficiency=0.075
GrassDistanceScale=1
FoliageDistanceScale=1
FoliageShadowDistanceScale=64
GrassRingSize=16777216
MaxVisibilityDepth=24
~ Optional ~
This forces streamer to load higher quality textures. (add at the end of file)
[Streaming/Textures]
UseMipRefiner=true
You can find additional possible var that could be specified inside config files here:
[Do not change those files - unless you know what you are doing.]
\The Witcher 3 Wild Hunt\bin\config\r4game\user_config_matrix\pc
Feel free to ask question about settings, I or someone else on the forum might be able to explain what do they do.
Here are links to pastebin for my own configs (note thay are little bit different from those settings, but feel free to use them)
resources.ini [All versions]
rendering.ini [v1.06]
performance.xml [All Versions]
My own user.settings [v1.06]
C:\Users[YourUserName]\Documents\The Witcher 3
User settings [v1.07]
http://pastebin.com/LdFd6Eed (Fixes performance issues ~WIP~ may have issues, may not work!)
http://pastebin.com/HbLjesFZ (Stable ~WIP~)
NV Tweaks, nice SS with comparison
CDPR Tweaks, descriptions
http://forums.cdprojektred.com/threads/36088-A-compendium-of-tweaks-and-fixes-for-the-PC-version
