http://pcpartpicker.com/nz/p/sITA
http://pcpartpicker.com/nz/p/sIK5
i already have a hard drive lying around
so i dont need to get one, and also im getting a: Raidmax Super Comet USB 3.0 Mid Tower Case, 500W PSU, Black
I would go with the AMD build. Why aren't you getting dual channel memory though?
i though i could upgrade to 8 in the future
Either build will do fine, for the price you are paying for that 640 you can buy a 7750 for the same price and get quite a huge peformance increase in gaming. http://www.anandtech.com/bench/Product/612?vs=535 This is a bench between the GT640 vs HD7750, the increase is huge.
thanx here is what it looks like now http://pcpartpicker.com/nz/p/sJ8y
You are posting quite a few different builds BIGASKD, which of them is the one you are most curious if it works?
sorry i want to know if the Amd (the last post) will work?
Why not a AMD apu?
Why would you spend $150 on a 7750 when there are 7770's on sale at some places for $130
the best value graphics cards are from previous generations on ebay. there you can pick up 560 ti's for like $150
